Old 07-10-2013, 12:36 PM   #1
esse10
Drives: 2009 yaris 2 door
belt
I just did mine two weekends ago and so far so good. NOt saying anybody here is wrong but I went with aftermarket brand on the belt. I did learn that you need to put anti-sieze on that bottom bolt holding the alternator. I believe that a belts life span is shortened when folks overtighten or leave it too loose, I've seen it happen first hand experience. This type of belt adjustment is old school skill of the craft way and if you have never done one before your gonna go through a learning experience before you get it right. I don't understand why Toyota didn't put an auto tension pulley like most modern cars, Maybe cost anyhow good luck folks and don't overtighten the belt or you'll create more problems.
esse10 is offline   Reply With Quote
follow up on 2010 yaris problems + more problems heavenswaitin DIY / Maintenance / Service 18 09-03-2013 03:47 PM
Seat Belt Problem wagon DIY / Maintenance / Service 1 03-06-2013 10:37 AM
Yaris problems heavenswaitin DIY / Maintenance / Service 3 11-02-2011 01:08 PM
NST Crank Pulley Reliability? WeeYari Performance Modifications 59 02-10-2010 01:20 PM
How can I get in touch with Toyota Regional Offices in Houston? woof DIY / Maintenance / Service 11 11-28-2009 09:29 PM
