Tw200--excellent!
Drives: 2010 yaris..absolutely red. Join Date: Jun 2010
Swidd......tightened the star until you could barely move the wheel?.....Now,are you saying after adjustment,you place the wheel back on and attempt to rotate or you are trying to rotate the unit with just the drum on? (much more difficult to rotate via the drum vs. the wheel being on.).If going that tight it would seem you would "burn-up" the drum and or the pads ASAP!!. Are you also adjusting the "nut" under the e-brake handle inside the car?;if so,is the plastic(s) a PIA to remove for this?. TIA
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| I dropped something down in my parking brake slot... | Boonespeed | Cosmetic Modifications (Exterior/Interior) | 12 | 08-11-2009 09:31 PM |
| Parking Brake Shoe Adjustment | bikegerm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 07-14-2009 02:26 PM |
| DIY For radios that require attaching a wire to parking brake | Slick | DIY / Maintenance / Service | 0 | 04-16-2009 08:14 PM |
| Parking Brake Adjustment Q's | Lafiro | DIY / Maintenance / Service | 3 | 04-13-2009 08:19 PM |
