Old 07-14-2009, 12:03 PM   #1
bikegerm
bikegerm's Avatar
Drives: 2007 Meteor LB
Parking Brake Shoe Adjustment
Hey there I just installed a rear disc brake conversion kit from Garm. Now my ebrake needs adjustment. With this kit there is actually a small drum and brake shoes inside the rotor assembly that only works for the parking brake. I need to adjust my star wheels out by using a brake tool that will go into the drum from the back of the mounting plate for the rotor. My question is, If I need to move my shoes out for more tension, do I push the star wheel or do I pull it towards me with the adjusting tool? I know, I could use trial and error and figure it out but it's easier to just get the answer.
Later....
Randy LeRoy
www.airshowmastering.com
randy@airshowmastering.com
bikegerm is offline   Reply With Quote
Old 07-14-2009, 01:42 PM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Did your kit not come with instructions?
Old 07-14-2009, 01:45 PM   #3
Brian
Brian's Avatar
You might wanna pull your star wheel off and check that it can be adjusted. Mine doesn't rotate.
I just pulled apart the center console and adjusted the tension for the lever. Works perfect now.
I tried adjusting it from the star wheel but it wouldn't move so I pulled the whole brake shoe assembly
apart and disassembled to strut assemble with the star wheel on it and it was 2 pieces, one slides
into the other, making it impossible to adjust. Another option is to use the brake shoe strut from your
original dums. I was gonna do that but I threw them away.
Old 07-14-2009, 02:26 PM   #4
bikegerm
bikegerm's Avatar
No... if it did, I wouldn't be asking. I'm not looking for sarcasm I'm looking for help.
Thanks Brian for the constructive help !!
Randy LeRoy
I dropped something down in my parking brake slot... Boonespeed Cosmetic Modifications (Exterior/Interior) 12 08-11-2009 09:31 PM
DIY For radios that require attaching a wire to parking brake Slick DIY / Maintenance / Service 0 04-16-2009 08:14 PM
Parking Brake Adjustment Q's Lafiro DIY / Maintenance / Service 3 04-13-2009 08:19 PM
