Old 07-23-2013, 08:50 PM   #1
Originally Posted by 2005vitzRS View Post
Thanks for the tip.
How do I know if I have a powered(amplified) antenna?
I have a 2005 Vitz RS. Its an import from Japan into New Zealand. Here is what the antenna looks like:
I had a look at this thread. My antenna plug is exactly the same as the one in this picture.
I bought a Toyota to ISO and an ISO to Pioneer wiring harness, plugged it all in, along with the antenna and the microphone.
It all worked.
I will test the FM reception on Monday when I am doing a trip and will see how well it works.
WOuld the harness have taken care of the antenna power?
Is there a noticeable difference between playing wav files and mp3's (All my mp3's are encoded at 320kbps)
The Vitz has an amplified antenna, as the Yaris does. The amplifier is part of the base of the antenna. The black wire on the blue connector outputs 12V to the amplifier. On aftermarket radios you can use the power antenna output to feed it.
Old 07-24-2013, 05:47 PM   #2
2005vitzRS
2005vitzRS's Avatar
Drives: 2005 Vitz RS, NCP91, Manual
Cheers for that.
I just pulled out the radio, checked for power on that black lead and it all looks good.
It looks like the harness has taken care of everything. Antenna amplifier is getting power. My FM reception problems seem to be limited to a particular station, in one or two areas. I may just install a new mask just to see if that helps. So all good, thanks for the help guys.
2005vitzRS is offline   Reply With Quote
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
Replacing Roof Top Radio Aerial (Antenna) KEVBD In Car Entertainment + Electronics (audio / video / alarm) 0 01-29-2012 02:17 PM
Replacing Radio WhiteNiteLite In Car Entertainment + Electronics (audio / video / alarm) 1 12-14-2011 10:20 AM
Custron T1062TYT Review (Long) mr.steevo In Car Entertainment + Electronics (audio / video / alarm) 1 11-24-2011 02:13 PM
ATL, I want to trade my Upgraded built in radio... matthewallanstill Southeast 2 03-28-2009 06:29 PM
