Old 07-30-2013, 09:48 AM   #3
jtw11
Drives: Smart Roadster Coupe
The C153 looks promising, given it's standard with an LSD as opposed to an open diff - at least that's what Wikipedia says, says it's from a Starlet GT Turbo with the 4EFTE engine...
I'm trying to find a picture of the stock pistons from the 1NZ and 2NZ to compare.
Correct me if I'm wrong, but the head and cams are identical between the 1 and 2 yes? So it follows that 1NZ pistons will work with custom rods.
jtw11 is offline   Reply With Quote
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
My 2010 yaris is on its 4th transmission!! Help please Uzairlexus DIY / Maintenance / Service 12 07-16-2013 10:46 PM
need experts helo on robotic transmission clutch mariann DIY / Maintenance / Service 0 10-03-2012 12:51 PM
Do I need a transmission flush at 57K miles if 07 Yaris should last until 100k? lejulie DIY / Maintenance / Service 14 10-23-2011 07:43 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
