Old 08-13-2013, 12:39 PM   #5
yaris1F8
yaris1F8's Avatar
Drives: Yaris 1F8
Its the screw closest to the top plate.. The cowl cover was making a poping noise and i thought it was something underneath.. got the car checked out a couple of times by different mechanics, found nothing wrong.. Finally i found out it was the cowl cover.. i saw it loose, and so i tightened the screw using a 10 mm short wrench.. i applied very little torque just with one finger and the screw just snapped. Ohhh so i said 'HO NO'... well i dismantled everything and got to work.. I drilled and retapped, i had no choice cuz the screw just didn't want to come out.. I retapped and put back in there a 10mm, a screw i had on my motorcycle.. Its all good.. and everything is solid now.. but you would think the car has very low millage at 27000 kms.. screws shouldn't be breaking off. If ever it gets loose again (I doubt it).. ill make the hole bigger and put in a 12mm.. I already have the screw. :)
yaris1F8 is offline   Reply With Quote
cant find the horizontal adjustment screw for headlight hatchback.. marcus Cosmetic Modifications (Exterior/Interior) 18 02-01-2017 03:26 AM
Quick and cheap: cover those ugly screw heads Kar98 Cosmetic Modifications (Exterior/Interior) 10 04-08-2013 07:32 PM
headlight screw size holding plastic bit jamsie81 General Yaris / Vitz Discussion 0 10-13-2011 01:14 PM
MI Armrest - New Screw? chrisj Cosmetic Modifications (Exterior/Interior) 5 10-04-2010 09:10 PM
screw it. thebarber Off-topic / Other Cars / Everything else Discussions 6 11-28-2008 05:45 AM
