#1 |
toyota
Drives: 2007 Yaris RS Blazed Join Date: Oct 2006
cant find the horizontal adjustment screw for headlight hatchback..
for the life of me i cant seem to find the vertical adjustment screw for 2007 hatchback headlight to aim it left and right. does it have one..the screw to adjust it up and down is right there but how do we adjust sideways???
i meant horizontal aiming..going left and right.. Last edited by marcus; 06-23-2010 at 10:53 AM. |
its the giant plastic thing sticking up on an angle towards the engine, iirc
#3 |
toyota
giant plastic thing?.. hmm let me post a photo if i can find one..
i think its horizontal aiming going left and right is what im looking for.. i see something on the manual ..is it possible we dont have left and right aiming? let me check. |
#4 |
left/right is a horizontal adjustment, not vertical
#5 |
toyota
yah horizontal is what im looking for i just check and it seems like we only got vertical adj cant find the other screw..maybe ill open it up later...
#6 |
I've never had need to adjust the lights so I'm not sure about horizontal either. IIRC, this adjustment can be done, but the headlight needs to be removed from the car.
I'm wondering if this is it shown in this pic I just took. This is looking at the passenger side light from across the engine bay.
#7 |
toyota
hmmmm i dont remember seing that one.. ill check later...thanks man..i may need to take it off just didnt want to do it and finds out there is no adjustment...just switch to hid and for some reason the left side is aimed more of the left rather than straight..
#8 |
im not sure you can adjust horizontally
whats the deal w/ your headlights?
#9 |
toyota
little off on aim on the left side. maybe its the way it was inserted...i can keep it the wa it is but id rather have it aim perfectly straight..
#10 |
In the diagram below, A is the vertical adjustment and B is the horizontal. The horizontal adjustment is part of the parking light bulb mount.
Headlight adjust.jpg |
#11 |
toyota
yah i saw this but i dont seem to have B..............
#12 |
#13 |
toyota
ok i found that piece it could be it but need a long screw driver to adjust but it doesnt seem to have a screw but i could be wrong..
#14 |
Drives: 07 Yaris Sedan Aero Join Date: Oct 2006
hmm.. i don;t seem to have found that one on my sedan...
#15 |
no screw
i was playing with it on my headlights last night...it pulls out like it were a bulb marcus, id just accept that your reflector headlights w/ HID's in them arent going to be perfectly straight
#16 |
toyota
cool good to know.. so we pull then turn to adjust left and right? actually the cutoff was ok little spread around it but i still got the 2 spots shining on the wall when i was adjusting.. that the reason i went with bixenon cos those came with shields on them..so looking at the headlight youll see top part of the headlight brighter than the half bottom..so far im happy..if not ican do projector but i think yaris projectors uses h1...
#17 | |
the depot headlights use h1's
#18 |
toyota
pls show me photos of this so called projectors...thanks bro. and ofcourse price. you are selling projectors right?
unless you meant the projector for stock housing which mean i have to open up the stock......if you throw in ur stock headlight with these projector i maybe interested.. shoot me a price. Last edited by marcus; 06-24-2010 at 02:24 PM. |
| DIY: Cargo Net for Hatchback Simplified [PICS] | KRAZGRL | DIY / Maintenance / Service | 13 | 04-22-2020 11:11 AM |
| Headlight adjustment screw question. | evan | DIY / Maintenance / Service | 6 | 01-09-2009 05:58 PM |
