Old 06-17-2009, 09:21 PM   #1
KRAZGRL
Crazy Girl (Kasey)
KRAZGRL's Avatar
DIY: Cargo Net for Hatchback Simplified [PICS]
I looked and didn't see this already on the list of DIYs, so I thought I would add it!
When you get the cargo net, it comes with instructions that makes it seem WAY more difficult than it has to be (taking out tool compartments by the spare, unscrewing/unbolting more things than necessary, etc). Which is the main reason I wanted to post pictures to show how easy it can be done. After installing cargo nets on both my hatchback and my mom's, it really takes only about 5-10 min max for actual install time.
Step 1
Gather the tools you need and the cargo net.
For the tools, I used:
Template (from packaged instructions) & tape
A center punch/hammer combination just to start a spot for drilling
Drill and a 15/64" or 1/4" drill bit (I used the 15/64")
Phillips screwdriver (I used my electric one to make things go that much faster)
Long screwdriver for prying up the panel
Step 2
Tape templates to side panels.
Step 3
Center punch (optional - to ensure accuracy) & Drill! Repeat for both sides.
Step 4
Remove the phillips head screw from the side panel, next to where you drilled. Repeat for both sides.
Step 5
Take the screw/hook that came with the net and install screw portion behind panel. This requires using the long flat head screwdriver to pry the side panel to where you can pull it enough to get your fingers behind (with the screw). Be careful not to drop the screw!!
Step 6
Screw on hook component to screw. Be sure to keep pressure on the back of the screw as you do this, to make sure it's on tight. Repeat steps 5 & 6 for both sides.
Step 7
Push/snap side panel back in place. Screw in phillips head screw that you removed in step 4.
Step 8
Put cargo net on hooks!
Old 06-17-2009, 09:47 PM   #2
Malaya1221
super duper M*******TOR
Malaya1221's Avatar
great job!
Old 06-18-2009, 09:41 AM   #3
Sparks Toyota-TRD
Drives: Toyota/Scion
Nice instructions! Great write up!
Tim
Sparks Toyota-TRD is offline   Reply With Quote
Old 06-18-2009, 03:24 PM   #4
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Good job!
Old 01-03-2010, 01:29 AM   #5
RedRide
RedRide's Avatar
I just got my cargo net in the mail, read the instuctiions and was like WTF?.........
As stated, it makes it seem way too contrived.
This make it much easier!
Old 01-03-2010, 12:28 PM   #6
YAR1S
YAR1S's Avatar
where does the bottom bit connect to, im confused? lol
-Jen <3
Old 01-03-2010, 12:56 PM   #7
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
It doesn't. The net is used like a pouch unlike what you're thinking of that would be in the tailgate of a pickup for instance.
Old 01-03-2010, 01:20 PM   #8
YAR1S
YAR1S's Avatar
ohhh! That makes even more sense.... I didnt see the point of it before.... neat.... stuff is always rolling around in the back of my hatch... I hold shopping bags together with a bungee wrapped from around the headrests.
-Jen <3
Old 03-24-2010, 12:26 PM   #9
RedRide
RedRide's Avatar
I finally installed my cargo net last weekend. I waited until warmer weather as I do not have a garage.
Anyway, it took me all of 10 minutes since I was in absolulty no hurry.
BTW, If anyone is thinking about getting one, I also have a cargo net in my other Toyota and they are definately handy/worth while and they are instantly removable.
Old 03-24-2010, 04:45 PM   #10
DARK AGE 53
Drives: 2009 Yaris Onyx
Nice write up, one question and one suggestion. Question, what's the cost of the net? Suggestion, what about putting a drop Loctite on the threads of the screw to help prevent it from coming loose?
Later,
Al
DARK AGE 53 is offline   Reply With Quote
Old 07-14-2010, 09:47 AM   #11
KRAZGRL
Crazy Girl (Kasey)
KRAZGRL's Avatar
Later,
Al
I want to say it was around $30? I honestly don't even remember. Plus it was a gift from my mom. (awwww)
The loctite is a great idea since the screws need a little tightening once in a while if you put the net up & down a lot.
Old 08-11-2010, 03:12 AM   #12
birdman
I love my net! Nice pictorial.
Old 02-18-2012, 02:52 PM   #13
MrMatt
Drives: 2008 Yaris #D Liftback Red
Thanks a lot... The installation instruction was very helpful.
I bought the net from eBay for $15. Unfortunately it did not come with Hardware kit.
A friend of mine at the Toyota Dealership identified the hardware kit as part# PT347-35991-HK ($4.27 with tax) . Even though the packaging says 4-Runner Hardware Kit it is identical and perfectly fits.
The installation was piece of cake (less than 10 minutes). One caution though. If you drop the screw you are screwed... I tied it with a piece of string in case it gets dropped between the panel.
Good luck…
MrMatt is offline   Reply With Quote
Old 04-22-2020, 11:11 AM   #14
kimona
kimona's Avatar
Drives: 2014 White VITZ
Reviving this really old thread!
A cargo net is great idea for some of us, and for less than $15 you can easily install one in your car using these easy to follow DIY instructions.
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 05:25 AM
How to put in my 'own' cargo net? fantabulousbaby General Yaris / Vitz Discussion 22 01-08-2007 03:54 PM
Liftback - Cargo Net Pompeii66 General Yaris / Vitz Discussion 22 09-04-2006 04:16 PM
