![]() ![]() ![]() ![]() ![]() Drives: LB-Auto-PWR-ABS-Cruise-Springs Join Date: Aug 2006
Synthetic Oil Cocktail
I needed to change my oil. (10K miles) I had 2 qts of Amsoil 0W-30, 1 qt of Mobil-1 0W-30, and 1/2 qt of Mobil-1 5W-30 laying around. I used a Napa Gold filter and in went the oils. It seems to run just fine, but I wanted some input from y'all on this. The 5W-30 was about 4 years old but was kept inside my house.
BTW - I overheard the Napa guy tell a customer to wait 'til you get 30K miles, then switch to synthetic oil, but you can never go back to conventional after that. LMAO! I wanted to ask him some more questions about synthetic oils but I was in a hurry. My brother was with me, being an ex-mechanic he was interested as well in what BS this guy was spreading on the subject. Where do they dream this stuff up?
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime Get YarAss in gear! RIP - Casey Tatum Last edited by nsmitchell; 04-02-2007 at 10:08 AM. |
As long as we're talkin about oil. I'm comin up on my first oil change as well. I don't even know what the Yaris takes now that I think about it. What would be a good "performance" synthetic oil?
VI VI VI
![]() ![]() ![]() Drives: Yaris S Sedan color Flint Mica Join Date: Jan 2007
AMSOil SAE 5W-30 Synthetic Motor Oil
2007 TOYOTA YARIS 1.5L 4-cyl Engine Code 1NZ-FE FILTERS Oil Filter........EAO09 AMSOIL Ea Oil FilterOil Filter........51394 WIX 51394 Oil Filter Air Filter........49104 |
#4 | |
No one game for a Synthetic Cocktail? Anyone ever tried it before. I don't think the additives should work against each other. I hope not anyway.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime Get YarAss in gear! RIP - Casey Tatum |
The Beautification of Car
have you guys got that The AMSOIL Preferred Customer Program?
#6 | |
4-stroke motorcycle engine oil in your car.. hummmm interesting.. also for light cars and diesels... about 1 dollar cheaper too. Last edited by Go4th; 04-02-2007 at 11:11 AM. |
TYPICAL PHYSICAL PROPERTIES (revised 02/05) AMSOIL Series 2000 Synthetic 0W-30 Motor Oil (TSO) Kinematic Viscosity @ 100°C, cSt (ASTM D-445) 11.2 Kinematic Viscosity @ 40°C, cSt (ASTM D-445) 56.9 Viscosity Index (ASTM D-2270) 195 Cold Crank Simulator Apparent Viscosity @ -35°C, cP (ASTM D-5293) 5520 Borderline Pumping Temperature °C (°F) (ASTM D3829) -40 (-40) Pour Point °C (°F) (ASTM D 92) -54 (-65) Flash Point °C (°F) (ASTM D 92) 226 (439) Fire Point °C (°F) (ASTM D 92) 247 (477) Noack Volatility (DIN 51581) 250°C for 1 hour, % weight loss 8.6 High Temperature/High Shear Viscosity cP, X°C, X s-1 (ASTM D4683) 3.4 Four-Ball Wear Test (ASTM D 4172: 40kgf, 150°C, 1800 rpm, 1 hr) Scar diameter, mm 0.39 Total Base Number >11.0 TYPICAL TECHNICAL PROPERTIES AMSOIL 100% Synthetic 5W-30 Motor Oil (ASL) Kinematic Viscosity @ 100°C, cSt (ASTM D-445) 10.6 Kinematic Viscosity @ 40°C, cSt (ASTM D-445) 55.8 Viscosity Index (ASTM D-2270) 185 CCS Viscosity @ -30°C, cP (ASTM D-5293) 5106 Pour Point °C (°F) (ASTM D-97) -50 (-58) Flash Point °C (°F) (ASTM D-92) 228 (442) Four Ball Wear Test (ASTM D-4172B: 40 kgf, 75°C, 1200 rpm, 1 hr), Scar, mm 0.35 Noack Volatility, % weight loss (g/100g) (ASTM D-5800) 7.1 High Temperature/High Shear Viscosity (ASTM D 4683 @ 150°C, 1.0 X 106 s.-1), cP 3.2 Total Base Number 12.2
Engineer/Artist/House-Dad
Drives: 2006 Toyota Sienna XLE Join Date: Aug 2006
hahaha, i dont know what those numbers all mean, but either one is a good choice! i really dont think mixing those oils will cause any damage in the short or long run. we all live under a budget, and we use what we can. if we werent on a budget, we wouldnt be driving the yaris! amsoil states that you can even mix their oils with conventional oils, so your mixture with other synths and synth blends should be just fine. its not like you're mixing 5w-30 with 10w-50 (totally different viscosities)!! now that would be cause for concern...
--B
His: 2006 Toyota Sienna XLE Arctic Frost Pearl, FC Package, 2007 Solara Nav unit, Spoiler, Running Boards & Auto-dimming rear mirror Hers: 2007 Toyota Yaris LB Black Sand Pearl, Auto, Power Package, Side Airbags, VIP security, USDM center armrest, and accessory 7 spoke 15" alloy wheels |
Drives: 2007 Yaris LB Join Date: Mar 2007
I hate it when people post with their sales BS instead of answering the original poster's question....to answer his question, NO the cocktaile you wrote of will not harm your engine.
To the Amsoil guys, could you please keep your commercial posts down to a minimum...otherwise I will complain to the web owners...and STAY ON TOPIC please! |
#10 | |
lol your funny.. shut up! |
#11 | |
![]() Drives: 2007 yaris hatchback Join Date: Feb 2007
thanks for answering the original post, now shut up |
#12 | |
Yeah, I am being a cheapskate. I had a little worry that something would go weird on my oil by mixing competing brands. Mainly worrying about additives doing weird stuff when combined, but like someone said earlier, if you can mix it with conventionals, I should be OK. The Mobil-1 5W-30 was the old formula. Maybe a synergistic effect will occur in wich I will achieve 200WHP and get 98MPG. Oh well, wishful thinking...
#14 |
#15 |
I mixed weights in my BMW motorcycle once and had no problems. I don't think it's a great idea but I'm sure your good to go.
#16 |
Or at least 2 ZPI Stickers! I want that turbo!
#17 |
#18 | ||
Why did you post this? Follow your rules from your 1st post please. |
| best synthetic oil and m/t oil?? | doodoo | DIY / Maintenance / Service | 122 | 04-03-2017 08:43 PM |
| Synthetic oil MPG boost since change | Yaris Dick | General Yaris / Vitz Discussion | 29 | 09-15-2007 08:15 PM |
| metal particles in oil | 007 hatch | DIY / Maintenance / Service | 9 | 06-22-2007 02:56 AM |
| When to switch to synthetic oil? | jay | DIY / Maintenance / Service | 65 | 02-15-2007 08:44 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
