#1 | |
Does your Yaris have the smart entry system or the engine immobilizer and if so, did you disconnect the battery when you were working on the fuel filter?
#2 | |
![]() Drives: '01 MR2 Spyder, '09 Yaris TS Join Date: Apr 2013
![]() Well I just stripped it again. The only thing that looks like it may be a problem is the strainer. Still doesn't explain why it does not start at all. No, this 2007 T3 has an aftermarket alarm system, but I'm pretty sure its not that...coz I can get the engine to swing. If the immobilser is not deactivated by button press on the remote, then it won't swing. But yes, I did disconnect the terminal before removal. I'm off to get the new Bosch fuel pump and strainer...man I am REALLY hoping that sorts it out.
'09 Yaris 1.8 TS - Hers '01 MR2 Spyder - My Track Project (TODA 20v) '94 Corolla 180i - My DD www.twincamclub.co.za |
So I replaced the fuel pump and strainer, and the car started on the first turn!
BUT...the low idle (500-600rpm), and shuddering is still happening when the car is idling...any ideas what this could be? ![]() Again when the a/c is switched on, the shuddering becomes worse...
#4 | |
Yes, I forgot to mention that...when I removed the plugs yesterday, I cleaned the maf and TB as well, just in case that was the issue.
I came across this thread: http://www.yarisworld.com/forums/sho...ht=shakes+idle I'm going to try another COP from my 1ZZ, and see if that sorts it out. After that, I'm stumped...really.
| Fuel Efficiency and the Yaris | BailOut | Fuel Economy Forum | 327 | 01-02-2026 11:44 PM |
| Fuel Filter | caveatipse | DIY / Maintenance / Service | 27 | 12-28-2012 09:45 PM |
| DIY - Cabin air filter location (Belta, Vios, Yaris sedan) | Murtaza_murti | DIY / Maintenance / Service | 5 | 04-05-2012 11:03 AM |
| Low fuel light | falkor_99 | General Yaris / Vitz Discussion | 35 | 08-24-2007 03:20 PM |
| fuel filter | ias205 | General Yaris / Vitz Discussion | 15 | 05-14-2007 11:02 AM |
