Old 08-19-2013, 08:41 AM   #9
Originally Posted by REV 2 11 View Post
Awesome, thank you!!
Not sure if it makes a difference, but the one I have has TWO rubber pipes at the top, and then the fuel outlet pipe...like the one shown in the first post here:
http://www.yarisworld.com/forums/showthread.php?t=38381
I was thinking of the wrong thing. There is not a plastic sleeve on the filter - The one I was thinking of is on the fuel pressure regulator (which is the smaller metal device that is visible when you pull off the strainer.
Does your Yaris have the smart entry system or the engine immobilizer and if so, did you disconnect the battery when you were working on the fuel filter?
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 327 01-02-2026 11:44 PM
Fuel Filter caveatipse DIY / Maintenance / Service 27 12-28-2012 09:45 PM
DIY - Cabin air filter location (Belta, Vios, Yaris sedan) Murtaza_murti DIY / Maintenance / Service 5 04-05-2012 11:03 AM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 03:20 PM
fuel filter ias205 General Yaris / Vitz Discussion 15 05-14-2007 11:02 AM
