It's unwise not to use a spring compressor -- you did it the best way without using one, but you also got lucky. Parts can go flying all over the shop/garage/yard doing it that way.
#2 | ||
It's Quacktastic!
Drives: '07 Yaris Hatch Join Date: Aug 2010
Also, be careful and don't cut too much off. If I had cut anymore off than I did, the overall length of the spring would have been too short for it to stay in place during moments of full droop (i.e. accidentally catching air on a railroad crossing). Quote:
(Especially so for those like the OP who use the spring compressor without the benefit of air tools.)And luck had nothing to do with it, I had a plan and knew what to expect and have done the same process on several other cars before. I would recommend doing it this way to anyone that feels confident in their mechanical abilities. |
![]() Drives: 2007 Toyota Yaris 4 door sedan Join Date: Jan 2012
[QUOTE=D&D;711228]If I had cut 1/2 of a coil off of either end then it would have posed a problem. But by cutting just 1/4 of a coil off of both ends, it retains the shape of the end of the spring enough to seat satisfactorily.
Also, be careful and don't cut too much off. If I had cut anymore off than I did, the overall length of the spring would have been too short for it to stay in place during moments of full droop (i.e. accidentally catching air on a railroad crossing). SO you cut a 1/4 inch top the top and the bottom? |
#4 | |
It's Quacktastic!
| Tags |
| springs strut front m2 |
| Lowered Springs - Toe, camber, caster alignment (Which ones)? | Henry_mak16 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 08-22-2013 01:33 PM |
| my 2012 yaris lowered on trd springs | dailygrindin | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 05-04-2013 10:08 PM |
| Just got my Yaris YRX Lowered on King Springs! | theconspiracymarket | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 08-03-2010 11:26 PM |
| lowered it DF210 springs | mikenacarato | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 30 | 11-27-2008 10:22 PM |
| NEED A PLACE TO GO GET MY SPRINGS INSTALLED IN NORTH NEW JERSEY | smokinyaris | NY / NJ/ CT / PA | 23 | 06-26-2007 11:25 PM |
