Old 08-09-2013, 02:19 PM   #1
Henry_mak16
Henry Mak
Drives: 2009 Toyota Yaris 2dr-hatchbk
Lowered Springs - Toe, camber, caster alignment (Which ones)?
I'm installing lowered springs soon, and once they settle in I'll be heading to an alignment shop. He says I won't be touching the caster alignment so it should be fine and I might need a toe and camber. Does that sound right? Or is just toe? o.o? Confused...noob here Thanks yarisworld
Henry_mak16 is offline   Reply With Quote
Old 08-09-2013, 02:58 PM   #2
The alignment should adjust camber and toe to whatever spec you say, including factory settings. I like a little negative up front on my cars.
Here all three so you can see them visually:
Old 08-09-2013, 03:19 PM   #3
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
And dont let them charge you for the rear lol
Old 08-20-2013, 12:22 PM   #4
D&D
It's Quacktastic!
D&D's Avatar
Drives: '07 Yaris Hatch
What do you mean? An alignment should always align all 4 wheels. Or do you just mean don't let them charge you twice?
D&D is offline   Reply With Quote
Old 08-20-2013, 12:32 PM   #5
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Because race car.
Old 08-20-2013, 02:18 PM   #6
There's nothing to align on the Yaris rear suspension. It can be adjusted with a shim kit or by unbolting/bolting the subframe, but I've never heard of it being needed.
Unless you were in an accident of some kind.
Old 08-20-2013, 02:23 PM   #7
D&D
It's Quacktastic!
D&D's Avatar
Ahhh, I see.. Learned something new today! ;)
Old 08-20-2013, 02:52 PM   #8
Toyota tried to get me for a 4 wheel alignment on my vibe....I told them 2 wheel only...rears were fine after a 2" drop (so were the fronts, actually)
Old 08-20-2013, 06:19 PM   #9
Yaristeve
Drives: 3-door hatch
I thought the ONLY adjustment possible on the front was toe?
Old 08-20-2013, 06:53 PM   #10
There is definitely a little camber adjustment available in the front. If you loosen both strut bolts, you'll feel a little play there, pretty sure.
Old 08-21-2013, 01:05 AM   #11
Yaristeve
Oh, okay. So it's not a real camber adjustment with slotted mounting holes and eccentric washers...
I wish Toyota had made at least the caster adjustable. As others have posted, the Yaris is kind of "darty" on the freeway and I was hoping to increase the caster a bit. Also, my steering pulls to one side which I was also hoping to increase caster on one side...
Old 08-21-2013, 01:23 AM   #12
I believe we have a bushing kit that corrects caster.
For more camber adjustment, you can do any of these, though I have always gone with option 1.
1. buy adjustable camber bolts
2. buy thinner Toyota fixed camber bolts
3. slot your struts.
Old 08-22-2013, 01:33 PM   #13
Yaristeve
Camber is not that big a deal to me (yet). Even when I lower it, it should go more negative. Plus I am used to the idea that camber is unadjustable without a camber plate on strut suspensions. But the Yaris is the first time I've heard of caster not being adjustable.
I don't like the darty feel of the steering (plus it pulls to one side) so I hoped to be able to increase caster.
Can a camber plate kit be turned 90degrees so that it becomes a caster plate kit? If so, does anyone make a camber plate kit for the Yaris or would I have to adapt one meant for another car?
Can I mess up my alignment when installing lowered springs? Henry_mak16 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 08-03-2013 08:05 PM
understeer DOMAV General Yaris / Vitz Discussion 31 09-30-2009 07:01 AM
Lowered today on tein springs...pics and alignment question Brentorius Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 09-27-2009 02:28 PM
Are camber bolts needed after installing springs? CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-01-2009 12:19 AM
Suspension alignment after new springs? mrrock Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 02-14-2007 01:05 PM
