Old 09-05-2013, 03:27 PM   #1
yarihari
Drives: 2002 Yaris T-Sport
Thanks for this, and also your other guides on getting the DTC out. Invaluable stuff :-)
I had a go but the middle connector is of a different size. I will try another model and will post an update later.
yarihari is offline   Reply With Quote
Old 09-05-2013, 03:36 PM   #2
Interesting. So the connector D4 (the middle one of the 3) was different? Did it have more or less pins, or was the plastic housing just physically different?
On the US 1st gen Yaris (aka Toyota Echo) D4 is identical from 1999 through 2005.
Need Help with 2NZ ECU pinout Aleil DIY / Maintenance / Service 3 12-28-2020 09:40 AM
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 01:50 AM
How to force OPEN LOOP mode on OE ECU?? maxthehax Forced Induction Forum 5 05-27-2013 09:42 PM
Yaris ECU broken??!!!!!! phb10186 General Yaris / Vitz Discussion 30 05-26-2010 09:56 AM
Tricking the ECU to Relearn AF map gwasabi Performance Modifications 126 05-16-2009 06:15 PM
