![]() Drives: 2002 Yaris T-Sport Join Date: Sep 2013
Thanks for this, and also your other guides on getting the DTC out. Invaluable stuff :-)
I had a go but the middle connector is of a different size. I will try another model and will post an update later. |
| Need Help with 2NZ ECU pinout | Aleil | DIY / Maintenance / Service | 3 | 12-28-2020 09:40 AM |
| I finally cracked the Odometer and SRS ECU code | CTScott | DIY / Maintenance / Service | 22 | 10-27-2016 01:50 AM |
| How to force OPEN LOOP mode on OE ECU?? | maxthehax | Forced Induction Forum | 5 | 05-27-2013 09:42 PM |
| Yaris ECU broken??!!!!!! | phb10186 | General Yaris / Vitz Discussion | 30 | 05-26-2010 09:56 AM |
| Tricking the ECU to Relearn AF map | gwasabi | Performance Modifications | 126 | 05-16-2009 06:15 PM |
