Old 09-24-2013, 06:56 PM   #6
yarihari
Drives: 2002 Yaris T-Sport
A wee update... I tried fitting an 89170-0D100 which I thought had a similar airbag configuration (drivers, pax, & side) but this came up with DTC's 31, 32 and 33. It also kept blowing the ECU-IG fuse which brought the ABS and handbrake warning lights up.
I was thinking I might try a 89170-52140 next - if I can get the drivers & pax to work I'll be happy.
yarihari is offline   Reply With Quote
Need Help with 2NZ ECU pinout Aleil DIY / Maintenance / Service 3 12-28-2020 09:40 AM
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 01:50 AM
How to force OPEN LOOP mode on OE ECU?? maxthehax Forced Induction Forum 5 05-27-2013 09:42 PM
Yaris ECU broken??!!!!!! phb10186 General Yaris / Vitz Discussion 30 05-26-2010 09:56 AM
Tricking the ECU to Relearn AF map gwasabi Performance Modifications 126 05-16-2009 06:15 PM
