Old 09-27-2013, 12:54 PM   #1
Jason@SportsCar
Originally Posted by Chuckie View Post
Check this video out. Spoon makes collars for Vitz/Yaris now. I just installed RZCrew Garage Collars on my Yaris. They make a big differrnce. Theres also another European company selling rigid collars online, (rigidcollars.com) for our cars.
http://youtu.be/zWyUD6UXfog
Does your car still have all the stock bushings? Hard to imagine any improvement being felt, or even measured, when you have massive rubber control arm and shock bushings in place - the upper shock mount alone has about a 1/2" of play in it. There is so much flex in the OE suspension, the subframe would be the last thing I would worry about. I also don't like the idea of lifting the body by placing a spacer between it and the subframe.
Interesting in the video... When they compare the two cars the blur on the "after" cars wheels seems to make it look like it was going faster when it hit the block, making the suspension instead of the chassis take the load - it would be easy to synch the videos in post production. Also the tire on the after car seem to deflect a lot more, another indicator of increased speed or lowered tire pressure.
Old 09-27-2013, 02:35 PM   #2
Chuckie
Drives: 2011 Yaris Hatchback
Yes im stock bushings all around still. My car is fairly new, 5k miles on it. I put the RZRCrew ones two weeks ago. Very obvious and noticeable difference even in my fairly new car. Tighter more solid feel immediately noticeable. Our roads here in the Philippines are sub par, alot of potholes and uneven surface conditions, worse than New Yor City, haha. I could really feel the difference when hitting these surfaces. I used to hear another sound other than just the rubber of the tires on the surfaces. Now, mostly all I hear is the rubber. I notice my car used to rock and wobble a bit just from these surfaces and jolts of acceleration. It doesnt do that anymore. Better handling and steering response. Prior to installation, My car was fully strutted on UR bars minus mid bar and rear upper. H&R springs on stock shocks.
Chuckie is offline   Reply With Quote
Old 09-27-2013, 02:47 PM   #3
Chuckie
It definetely feels like a more expensive car. My father has an IS 300. Collars bring it closer to that feel. In more expensive cars they dont take as many manufacturing shorcuts. Oh, and ride height is unchanged.
Old 09-27-2013, 03:29 PM   #4
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Interesting in the video [...]. Also the tire on the after car seem to deflect a lot more, another indicator of increased speed or lowered tire pressure.
I did notice that the tire in the "after" shot looked under-inflated. I guess I'm not alone on this...
Old 09-27-2013, 08:52 PM   #5
Viperoni
Drives: 2005 Toyota Echo
QFT.
Echo's don't have this collar, but Jason's right on point - the factory suspension has way more flex than any positive effect this would ever have...
2006 Saturn Ion Redline
Old 09-28-2013, 01:03 AM   #6
Chuckie
Originally Posted by Viperoni View Post
QFT.
True, but your'e dealing with two fairly independent systems. Like stated in the video, on race cars, these areas where the bolts are that connect the body to the subframe, these parts are actually welded. Its not really the suspension its working on but rather the connection of the engine, transmission and suspension to the subframe which is a rather lose and you can say primative connection on alot of non luxury or more expensive sports cars. The effect of play in the stock suspension is independent of of the effect of rigid collars since they are separate areas in a cars makeup. Thats like saying if you add a front upper strut bar, there would be no positive effect unless a rear strut bar were added as well.
Old 09-28-2013, 01:16 AM   #7
Chuckie
Note: I have the UR front lower 4 point stress bar. Apparently, these are four of the bolts that connect the body to the subframe. The collars go in first and strut bar slaps on after.
FS: Full NCP91 KavinT Manseth Kit (Front Bumper has Damage) Treyz Items for Sale by private party 22 04-08-2014 06:17 PM
RZCrew Garage Rigid Collars Chuckie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 02-13-2014 12:34 AM
SilkRoad NCP91 Coilovers In-Stock! Penguin Garage Penguin Garage 28 07-12-2009 05:48 PM
