Old 09-27-2013, 08:52 PM   #7
Viperoni
Drives: 2005 Toyota Echo
Originally Posted by Jason@SportsCar View Post
Does your car still have all the stock bushings? Hard to imagine any improvement being felt, or even measured, when you have massive rubber control arm and shock bushings in place - the upper shock mount alone has about a 1/2" of play in it. There is so much flex in the OE suspension, the subframe would be the last thing I would worry about. I also don't like the idea of lifting the body by placing a spacer between it and the subframe.
Interesting in the video... When they compare the two cars the blur on the "after" cars wheels seems to make it look like it was going faster when it hit the block, making the suspension instead of the chassis take the load - it would be easy to synch the videos in post production. Also the tire on the after car seem to deflect a lot more, another indicator of increased speed or lowered tire pressure.
QFT.
Echo's don't have this collar, but Jason's right on point - the factory suspension has way more flex than any positive effect this would ever have...
2006 Saturn Ion Redline
2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold
2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped
Viperoni is offline   Reply With Quote
FS: Full NCP91 KavinT Manseth Kit (Front Bumper has Damage) Treyz Items for Sale by private party 22 04-08-2014 06:17 PM
RZCrew Garage Rigid Collars Chuckie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 02-13-2014 12:34 AM
SilkRoad NCP91 Coilovers In-Stock! Penguin Garage Penguin Garage 28 07-12-2009 05:48 PM
