Old 10-06-2013, 09:00 AM   #1
adeen
Drives: 08 Toyota Vios
behind the relay in the cabin theres one yellow wire, two purple wires separately and two red wires in one socket...if i locate the red wire and connect the red wire from the fog light, would that suffice? i just want the fog light indicator to light up as it should
adeen is offline   Reply With Quote
Old 10-06-2013, 09:28 AM   #2
Using that red wire would be fine.
I actually recommend following the DIY in the link below, which I created for Micro Image instead, as the one in this thread leaves the switching and illumination circuits bridged, which results in the light on the switch being illuminated, even when the car is off.
http://microimageonline.com/forums/s...n-Instructions
Fog light install 07yaris_fe Cosmetic Modifications (Exterior/Interior) 10 07-20-2010 01:18 PM
Looking for the Toyota Fog Light install RocknRollRon DIY / Maintenance / Service 33 06-13-2010 06:46 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
Before I start calling around: fog light install prices St_G Cosmetic Modifications (Exterior/Interior) 4 03-17-2007 09:45 AM
Finally installed oem ebay fog light for hatchback Adriaan General Yaris / Vitz Discussion 6 12-27-2006 04:24 PM
