Old 10-15-2013, 12:21 PM   #1
caper26
caper26's Avatar
Drives: 2010 4D Sedan 5M w/convenience
I had the codes read with OBD II. It was misfire on 2 & 4, and random misfire codes. Wondering what I should do now.
caper26 is offline   Reply With Quote
Old 10-15-2013, 12:45 PM   #2
bairjo
I think CTScott already gave a suggestion
bairjo is offline   Reply With Quote
Old 10-15-2013, 01:29 PM   #3
Clear the codes. Swap the coils from 2 & 4 with 1 & 3. If the coils are bad, then the next cel should indicate misfire on 1 & 3. If it is still 2 & 4, then spark plugs are next to look at.
Old 10-16-2013, 12:27 PM   #4
caper26
caper26's Avatar
Thank you. This is really annoying with under 40K km's. I cleared the code last week, and will see if it returns.
I read somewhere there has to be a certain number of misfires before the CEL lights up?
Check Engine Light P0455, P0441, P0456 RedStickHam DIY / Maintenance / Service 8 12-01-2013 12:41 PM
help..check engine again dindy DIY / Maintenance / Service 12 12-13-2012 06:17 PM
MAF check engine light and transmission help heeroyuy01195 DIY / Maintenance / Service 22 04-03-2012 02:16 PM
yaris engine check light keeps coming on mattuk10 DIY / Maintenance / Service 6 07-24-2010 11:44 AM
Check Engine "Injector failure Code" YarisPR DIY / Maintenance / Service 14 03-04-2007 08:13 PM
