Old 10-17-2013, 04:16 PM   #1
jayeh
Drives: '08 Yaris LB
Originally Posted by silentassassin View Post
I found it alarming as well, but i only had the car for 2 weeks or so. So i guess ill get used to it. Also will reving it more hurt the mpg? thanks again for all your help guys.
Nope, although the mpg drops the higher you go obviously.
Remember that similar cars get the same mpg as the Yaris (or lower) and they all have 5-6 speed automatics too!
Originally Posted by tooter View Post
That sounds a little high to me. Is your Yaris an automatic? Mine does 2,600rpm @ 60mph on the freeway with a stick.
Greg
The AT is definitely a bit higher than that.
jayeh is offline   Reply With Quote
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 RPM JEFF Great Lakes 0 09-24-2012 04:40 PM
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 RPM JEFF Mid-Atlantic 0 09-24-2012 03:10 PM
Vitz 2001 1.0 manual rpm diesel2901 DIY / Maintenance / Service 4 09-23-2011 12:02 AM
Turbocharged Dyno Result cdydjded Forced Induction Forum 24 08-23-2010 10:54 PM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 12:41 AM
