![]() ![]() Drives: 2007 Yaris sedan Join Date: Nov 2011
Mine is located in the little pocket on the passenger side of the center console i don't know why it doesn't work right do you think I have to get a new stereo
#2 | |
This is what an OEM one looks like:
it is actually in the pocket. this is why its such a pain in the ass to have to adjust to get it to work. it is hard enough just to get it plugged in. ill get a picture of it when I go out to my car. the head unit is a little different, but the auxiliary port looks the same .
#4 | |
If you existing one can be made to work by holding the cable in just the right position, then the inside contacts of the jack have gotten bent to the point where they no longer spring back into the proper position. In that case, you will be best of replacing the jack assembly, rather than trying to repair it.
by replacing the jack assembly do you mean just the little black box with the plug on it? honestly though is it worth spending the money on a new stereo to power my speakers ? if you think that is the better way to go then I will probably just go that route.
#6 | |
#7 | |
![]() ![]() ![]() Drives: 2007 Toyota Yaris Hatchback Join Date: Sep 2012
| Aux Port - Canadian 2006 Yaris | spryguy007 | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 04-17-2022 12:33 PM |
| Anyone had an OE head unit apart? (aux port) | CoryM | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 05-23-2012 09:42 PM |
| How do I can install (AUX) Port ??....>> | boadel | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 02-15-2010 05:40 AM |
| Switched amp for AUX port with Aftermarket stereo? | CtrlAltDefeat | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 05-28-2009 02:34 AM |
| question bout aux port | SurfBabe900 | General Yaris / Vitz Discussion | 1 | 05-28-2007 02:18 PM |
