Old 11-12-2013, 07:03 AM   #1
the ccfl "ballast" from post 1 connects to the ccfl cord from the projector. you tap the red/black wires from the ccfl ballast to your parking lights to run the halos with your parking lights
the other plug goes into the wiring harness which was also in the box. it controls the flap inside the projector to open for your high beams
make sense?
edit, no splicing of the wiring harness included! the only thing you'll have to do is use the wire taps with the kit to tap into your parking lights to turn the halos on/off
Old 11-12-2013, 08:13 AM   #2
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
make sense?
Okay, I got the CCFL figured out. Thanks man!
But how does the high beam control plug into the wiring harness? They both appear to be female, i've tried to connect them and they're both the same connection; one doesn't go in the other.
My first picture is the one of the wiring harness, it's the same connector as the projector.
The second picture is a picture of the connector i'm talking about, they're both exactly the same.
Unless I didn't see a part in the box?
It does look awesome! It looks even better in person, I just wish I knew more about wiring and didn't have to ask such silly questions. XD
Black_griffin6 is offline   Reply With Quote
Sedan HID Projector Retrofit Headlights !yaris! Cosmetic Modifications (Exterior/Interior) 10 10-26-2017 02:31 AM
Voltage regulator and Amperage question... cr.chango DIY / Maintenance / Service 13 11-24-2009 12:59 PM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 03:57 AM
Retrofit Question ChinoCharles Cosmetic Modifications (Exterior/Interior) 19 05-13-2009 06:20 PM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
