Old 11-28-2013, 01:12 AM   #1
thomas667
Drives: 2011 yaris
Originally Posted by IllusionX View Post
weird.. a normal wrench did the trick here.
Don't know what a normal wrench is bt if use a 3/8 ratchet it hits the crank pulley and ur on an angle which will strip the bolt bt hey to each his own .
thomas667 is offline   Reply With Quote
Old 11-28-2013, 09:29 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
use a wrench instead of a 3/8 socket drive.
Old 11-28-2013, 11:43 AM   #3
Yeah, thanks to the A/C lines, it is a very tight space. Depends on your ratchet set. I have one 3/8" that will not fit, and another with a slightly thinner head which will just clear the lines. I use it to break the bolt free, then finish backing it out with a wrench.
Belt Tensioner for the Yaris fmicle DIY / Maintenance / Service 25 11-26-2022 11:37 PM
Could the 07-08 yaris s front lips actually fits 2010 yaris? Adward10 Cosmetic Modifications (Exterior/Interior) 3 03-18-2013 12:06 AM
