2ZR swap. DO IT! Ask how!
Wow, that's a really nice setup! I've played with Arduinos at school, and have seen a few people use BT communications.
I've got a scangauge II and it's a very useful tool. It can monitor anything on the OBD-II diagnostics bus, plus anything that you "find" the OEM codes for. It also reads and clears diagnostic trouble codes (DTC)/check engine light (CEL) errors, can record performance data (0-60, 1/4 mile, etc), and a few other neat things that are escaping me at the moment. |
#2 | |
Embracing Curves
Drives: '14 Prius Executive Join Date: Aug 2013
![]() I have been thinking about adding an automatic contrast compensation (I have to correct it when the interior and the display have reached a higher temperature, otherwise it gets all black), sadly this will be a bit tricky because it is a negative voltage :/ |
#3 | |
![]() You may be better off finding an "extended temperature range" version of that display. |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| Need help ASAP, fuel gauge / shipping car | PolarBear | DIY / Maintenance / Service | 2 | 09-25-2012 11:06 PM |
| DIY Oil Pressure Gauge Install | LtNoogie | DIY / Maintenance / Service | 13 | 11-20-2009 04:13 PM |
| rpm gauge installation diy | zumoney | DIY / Maintenance / Service | 1 | 03-25-2009 03:16 AM |
