Old 12-03-2013, 04:45 AM   #1
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
Originally Posted by CrankyOldMan View Post
I've played with Arduinos at school, and have seen a few people use BT communications.
Not so old, huh?
I have been thinking about adding an automatic contrast compensation (I have to correct it when the interior and the display have reached a higher temperature, otherwise it gets all black), sadly this will be a bit tricky because it is a negative voltage :/
dj92 is offline   Reply With Quote
Old 12-03-2013, 05:22 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Originally Posted by dj92 View Post
Not so old, huh?
Ahem, University.
You may be better off finding an "extended temperature range" version of that display.
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
Need help ASAP, fuel gauge / shipping car PolarBear DIY / Maintenance / Service 2 09-25-2012 11:06 PM
DIY Oil Pressure Gauge Install LtNoogie DIY / Maintenance / Service 13 11-20-2009 04:13 PM
rpm gauge installation diy zumoney DIY / Maintenance / Service 1 03-25-2009 03:16 AM
