Angry Bird
I know and I let it go inmmediately...after I let it go the car turns on and the starter is still going it does this some times mosty when its cold
![]() ![]() ![]() Drives: '08 5-door Join Date: Apr 2009
OK, it's probably a problem with the starter - maybe the solenoid is sticking, as CTScott suggested. If something like oil or antifreeze has been leaking into the starter, it could combine with dust to form a sticky mess that will cause the starter drive to jam. Another possible cause is the ring gear on the flywheel (the big gear that the small pinion on the starter drive engages). I have seen some really chewed up ring gears that are reluctant to let the drive retract after starting. Check for this condition by removing the starter and manually turning the engine over, examining all the teeth on the ring gear carefully. Suggestion for the next step: you should dismantle the starter for cleaning (cheap) or replace it (expensive.)
| Starter sticking or ??? | CueBall | DIY / Maintenance / Service | 4 | 09-07-2014 01:52 AM |
| Starter Kill | david.gartee1 | DIY / Maintenance / Service | 7 | 03-01-2014 07:14 AM |
| Remote Starter - Tail Light Problem | Chrsto4 | General Yaris / Vitz Discussion | 4 | 10-31-2009 11:36 PM |
| starter kill & horn help | spechuy | DIY / Maintenance / Service | 0 | 10-20-2008 01:30 PM |
| Starter dragging | YarisTom73 | DIY / Maintenance / Service | 5 | 08-27-2007 12:11 PM |
