#1 | |
Hopefully the issue is that your coolant temp sensor is actually bad. I have experimented with clusters from other regions and the temperature lights always worked correctly, as the cluster just receives a CAN bus signal from the ECM with the temperature. Definitely not an ECM issue.
#2 | |
![]() Drives: Yaris M2 1.0 Join Date: May 2016
So it looks like everything is working fine. Thanks again, Matteo |
![]() Drives: Toyota Yaris 2006 1.0 VVT-i Join Date: Jun 2016
Hello,
If I want to change my VFD speedometer (Yaris 2006) with one newer from (yaris 2009) - I need also the immobilizer? Thanks, |
Drives: yaris Join Date: Nov 2016
Hi. I'm looking for pinouts for the connectors of an instrument cluster panel for yaris 2015. I've seen the Yaris Instrument Cluster Wiring (USDM vs European vs Japanese) document, but for the PCB I have, D1 has 40 pins, and D2 13 (they also labeled differently - CNA and CNB). Any suggestion of where I could find some schematics would be greatly appreciated. I wasn't able to find anything so far
The part number is 83800-0u191.
| Tags |
| cluster, digital, gauges, intsrument |
| Custom Instrument Cluster LED Color Change Service | CTScott | Items for Sale by private party | 74 | 06-10-2022 01:29 AM |
| Cruise Control - 07/08 Sedan - Instrument Cluster | CB900F2 | DIY / Maintenance / Service | 4 | 02-23-2011 07:03 AM |
| DEAD INSTRUMENT CLUSTER! | yaris2010RS | General Yaris / Vitz Discussion | 21 | 02-24-2010 12:06 PM |
| Sedan Instrument Cluster to LB Instrument Cluster | Malaya1221 | Cosmetic Modifications (Exterior/Interior) | 2 | 12-02-2008 10:05 PM |
| instrument cluster swap S -> LB | elo79 | Performance Modifications | 1 | 12-21-2006 10:22 AM |
