![]() ![]() ![]() Drives: 2005 Toyota Vitz RS Join Date: Jan 2012
I would like orange.
Yes, those 2 wires are in a white connector, they seem to be going up to that immobilizer light (the one near the defrost windshield vent) . Is there anyway I can check this is the ambient temp sensor, if not where is ambient temp sensor normally found ? If I dont have the ambient temp sensor, could I buy one (from you) and wire it in to work with this meter ? Oh and any word on if I can easily change units in my meter ? thanks. |
#2 | |
Orange would be no problem. Are you looking for about the same color as your analog cluster had? I am 90% sure that the unit supports going back and forth between KM and Miles. Once you power it up, you hold the odo trip reset switch for more than one second with the tail light switch off to switch display units.
| Tags |
| cluster, digital, gauges, intsrument |
| Custom Instrument Cluster LED Color Change Service | CTScott | Items for Sale by private party | 74 | 06-10-2022 01:29 AM |
| Cruise Control - 07/08 Sedan - Instrument Cluster | CB900F2 | DIY / Maintenance / Service | 4 | 02-23-2011 07:03 AM |
| DEAD INSTRUMENT CLUSTER! | yaris2010RS | General Yaris / Vitz Discussion | 21 | 02-24-2010 12:06 PM |
| Sedan Instrument Cluster to LB Instrument Cluster | Malaya1221 | Cosmetic Modifications (Exterior/Interior) | 2 | 12-02-2008 10:05 PM |
| instrument cluster swap S -> LB | elo79 | Performance Modifications | 1 | 12-21-2006 10:22 AM |
