#19 | |
![]() Drives: 2 Door hatchback Join Date: Feb 2010
#20 |
My R1 eats my Vitz!!
Drives: '07 Vitz Lifty, Stick Shift Join Date: May 2007
I also just ran into this problem pretty recently. At first I thought it was my gas cap, but after refitting it ten times my CEL is still on. Anyway I found the TSB too and was wondering if I just change the Pipe holders that it mentions, will this make the CEL go away, or will I have to change all the part numbers in the TSB (ie. the 800 dollar Vapor canister). I sure hope not, seeing as the pipe holders are less than 20 bucks. Also someone mentioned the solenoid that's near the vapor canister sometimes sticks, and maybe I can just take that out and try to free it up?? Well we'll see and any input would be nice...seeing as I live in New York and they have damned inspections :(
My Car Rules! |
#21 | |
#22 |
![]() Drives: 2008 yaris Join Date: Feb 2012
I was reading up on some of these forums. i bought my wife a 2008 yaris brand new. Have not had any problems until i got the emissions notice. Literally after i got the notice here check engine light went on......of course. I have been reading all of these symptoms, ALL of which i have, all the codes, etc. BUT this car is a 2008!! which is supposed to be the "updated" version of the filler neck etc....Now what do I do??? Obviously they didnt fix much!!
#23 |
Drives: Toyota Yaris 2007 Join Date: Feb 2011
Solved: 0043E, P043F, P2401, P2402, P2419
Hello,
I've got a Yaris 2007. I had the check engines codes 0043E, P043F, P2401, P2402, P2419. I solved the problem: 1) Replaced the charcoal canister; got one from the scrap yard (135$). The dealer would ask 800$ for a brand new. ![]() 2) The check engine light (CEL) went off by itself, and never came back. ![]() The charcoal canisters are compatible with Yaris 2006-2011. I did not apply any other repair procedure. Good luck guys! Pat |
#24 | |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#25 |
Drives: yaris Join Date: Apr 2012
My 2007 yaris engine light was on.. Turns out I needed a new vapor canister. Dealer wanted $1200 installed.. I got mine from the wreckers for $100.. Gave it my mechanic and he installed it for $40.. He reset the codes and I drove the car for a day for the new part to register.. Went and passed the emmiisions.. Don't buy new.. Get from wreckers
#26 |
![]() ![]() ![]() Drives: 2015Yaris, Son's car, 10 Prius Join Date: May 2010
just a reminder
I see this all the time, where at the gas pump, people are topping off their tank. From what I understand, topping off will kill your vapor canister. Stop at first click off. Even some gas stations have warnings about this.
But you still see click click click click. oh well. |
