#18 | |
Looking at the TSB, there is a replacement Fuel Tank Filler Pipe Cover that is supposed to seal better. You may want to also see if you can grab that from on 08, or if you can talk you dealer into giving it to you. If you want a copy of the TSB, it is posted in a stickied thread in the DIY section of the forum. TSB.jpg |
