#73 |
For just an intake manifold spacer, these are awesome gains!
#74 | |
play every day
So extrapolating the results I got with my engine, the spacer would only make about 92 horsepower and 94 foot pounds of torque. Note on the graph that the peak values for both hardly go up at all with the spacer. The biggest difference is in the profile of the torque curve, and that the torque peak is reached 450 rpm sooner. |
#75 |
play every day
It's not so much the peak gains themselves as they're actually quite small, it's more how they're distributed in particular the torque. I was really happy with the results on my Tacoma, and the Yaris turned out even better than the truck.
![]() Greg |
#76 | |
play every day
Greg |
#77 |
toyota
tooter just curious if theres an issue with the stock airfilter box moving 2 inch forward?
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!! "Horsepower is how fast you hit the object. Torque is how far you move that object.." |
#78 |
Sorry Greg, that came in higher than I thought it would. I do applaud the results of your insatiable curiosity.
Look forward to seeing what you dream up next.
#79 | |
play every day
I do know the lines that circulate coolant through the base of the throttle body will be too short. So I simply connected them to each other using a short scrap of tubing as a coupling. Greg |
#80 | |
#81 |
play every day
Thanks Garm.
![]() Then it's $16 extra to ship to Canada. I posted a thread in the For Sale section where anyone can add their name if they're interested. Greg |
#82 |
toyota
i was hoping itll be under $200 shipped.. but it is definetely something to think about..
#83 |
My thing was that tooter usually makes short runs of products. I was thinking of doing this later on but the issue is they may not be available so I am going ahead and biting the bullet.
I guess that is the thing with specialized products. I joined after the Piggies short throw shifter was long gone so I had to wait for garm to come out with his. Waiting about killed me so I am a little more apt to jump on something if I know quantity is limited. |
#84 | |
play every day
![]() Greg Last edited by tooter; 02-06-2014 at 07:15 PM. |
#85 | |
Guess i should get this spacer rather than a exhaust header, more practical to have the same torque at lower rpms (everyday driving RPM). My guess is Id save a little gas by being able to be in 5th doing 25mph in Residential area. Also probably can stay in 5th and still have passing torque on freeway. **So this spacer moves the same profile curve to the left. And the tooter manifold with 1ZZ TB just gives higher max numbers. Between those two, the spacer is better for a normal day to day use car?
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 Last edited by ezhacker1; 02-06-2014 at 08:53 PM. |
#86 | |
play every day
Sorry man... it's extremely expensive to design, test, and manufacture small amounts of highly specialized parts. So everyone gets to weigh the cost to benefit ratio and decides for themselves. Greg |
#87 |
toyota
dont apologize ..no worries i kinna understand the whole process..
#88 | |||
play every day
Now that the ECU has settled in and the car is all gassed up, I'm ready to log some mileage readings. I'll let you know the results, for better or for worse. Quote:
![]() I'm going to experiment with the tooter et manifold by taking off the top of the plenum, and see if I can lengthen the runners from the inside. ![]() Greg |
#89 |
![]() ![]() Drives: 2002 Toyota Yaris T-sport Join Date: Jan 2014
Those are quite spectacular g ains, very nice! :)
2002 Toyota Yaris T-sport ![]() 198X BMW E30 modified race car ![]() 1975 Ibanez "Les Paul custom" |
#90 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
I may just have to get this...trade for my tooter? My car is DD more then race car ;)
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
| tooter's manifold adventure... | tooter | Performance Modifications | 1465 | 07-31-2014 08:11 PM |
| FS : GT2560R Turbo + Manifold | Parmas | Items for Sale by private party | 0 | 08-24-2012 08:35 AM |
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
