Old 02-05-2014, 12:26 PM   #1
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
tooter just curious if theres an issue with the stock airfilter box moving 2 inch forward?
I don't know because I run a short ram that just moves along with wherever stock throttle body is. The stock rubber hose is pretty flexible, but I don't know if it will offset 2 inches.
I do know the lines that circulate coolant through the base of the throttle body will be too short. So I simply connected them to each other using a short scrap of tubing as a coupling.
Greg
Old 02-06-2014, 05:09 AM   #2
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Greg
Bypassing the coolant flow through the throttle body, probably marginal lower intake air temp.
Guess i should get this spacer rather than a exhaust header, more practical to have the same torque at lower rpms (everyday driving RPM).
My guess is Id save a little gas by being able to be in 5th doing 25mph in Residential area. Also probably can stay in 5th and still have passing torque on freeway.
**So this spacer moves the same profile curve to the left. And the tooter manifold with 1ZZ TB just gives higher max numbers. Between those two, the spacer is better for a normal day to day use car?
Check out my Build thread:
Old 02-06-2014, 12:16 PM   #3
tooter
play every day
tooter's Avatar
I don't know... that TRD header in the For Sale section is a really good deal . And from looking at it's design with the slightly longer runners, it would also add bottom end torque. I just don't know how much.
My guess is Id save a little gas by being able to be in 4th doing 25mph in Residential area. Also probably can stay in 5th and still have passing torque on freeway.
The spacer makes it easy to short shift at 2,000 rpm around town without lugging the engine. It's also really easy to take off from a standing start without a lot of clutch slipping or revs. It generally makes normal everyday driving more pleasant.
Now that the ECU has settled in and the car is all gassed up, I'm ready to log some mileage readings. I'll let you know the results, for better or for worse.
For regular transportation driving... the tooter I.V spacer beats the hell out of the tooter manifold!
I'm going to experiment with the tooter et manifold by taking off the top of the plenum, and see if I can lengthen the runners from the inside.
Greg
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
FS : GT2560R Turbo + Manifold Parmas Items for Sale by private party 0 08-24-2012 08:35 AM
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
