^ You'd be better off with a full standalone like AEM EMS or similar. I don't think a Megasquirt has nearly enough functionality to replace the stock ECU.
#2 | |
![]() ![]() Drives: vitz rs Join Date: Apr 2011
Simply I reconnected stock denso ecu and I go. Very slow but I go. And I have all time to look and solve issue. Stock ecu is inside car so no prob to disconnect emanage harness and put toyota wiring. If I had standalone sure denso ecu rip home then if there's an electric problem engine does not start and car rip where it is.. mountains or seas. BUT.. emanage is headache cause billions of menu and parameters and not all is working.. idle adjustment not working properly or it is too difficult to me to understand.. it is japanese.. it is weird. If I decided to go standalone I buy apexi power fc. Yes it is japanese, all that's electical is japanese, but it has toggle to easily map onboard and costs 1000usd not aem standalone 2000usd. Why do Uu suggest aem? Is u official dealer? Do u provide all aftermarket support? Yes all of my temp e press gauges are aem working fine. Only egt probe lasted so short and I replaced with an other brand breaking after short and replaced with other brand 1 month ago. Then egt probe is short life. |
| Need Help with 2NZ ECU pinout | Aleil | DIY / Maintenance / Service | 3 | 12-28-2020 09:40 AM |
| I finally cracked the Odometer and SRS ECU code | CTScott | DIY / Maintenance / Service | 22 | 10-27-2016 01:50 AM |
| standalone and stock ecu | Radou | Performance Modifications | 0 | 06-16-2013 04:47 PM |
| Yaris ECU broken??!!!!!! | phb10186 | General Yaris / Vitz Discussion | 30 | 05-26-2010 09:56 AM |
| Tricking the ECU to Relearn AF map | gwasabi | Performance Modifications | 126 | 05-16-2009 06:15 PM |
