![]() ![]() Drives: Vitz S 2007 LB Join Date: Feb 2013
1NZ-FE ECU
how many types of ECU are there for our engines? for what i know, japanese ecus, thailand, european and american ecus are all different... can anymone shed some light on this?
There are very many. For the US market alone there are over 20 separate part numbers. The variations for our market include different features (ABS, traction control, transmission type) and regional differences (US, Canada, Puerto Rico and Mexico specific ECMs).
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Is there any benifit to run say a jdm one?
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
No, if your state does emissions testing, as the JDM ones don't speak OBDII.
Mine is an obd2.
#6 | |
Either i get one new chipable ecu, or i have to rely on emanage. Which i have no idea what can emanage control |
#7 | |
Embracing Curves
Drives: '14 Prius Executive Join Date: Aug 2013
A Megasquirt *might* be a possible alternative - however, it's a huge lot of work, as you'll have to let it emulate the former ECU in order to satisfy e.g. ABS and the tachometer.
^ You'd be better off with a full standalone like AEM EMS or similar. I don't think a Megasquirt has nearly enough functionality to replace the stock ECU.
What about emanage?
![]() ![]() Drives: Axio GT Join Date: Apr 2012
Well,emanage ultimate is good but coming from someone in Japan,who is running a forged setup with emanage ultimate,the main issue he had was,running rich [no matter what] top end. But he is very secretive about what mod he did to sort out this issue. :(
What kind of setup do you have? If you are running only 0.5 bar pressure,like on the stock TRD boosted engine [1nz] then the stock TRD Ecu is good enough. |
Well, the mods i have right now is just minimal. K&n dropin, lighten crank pulley, 421 exhaust manifold, doing the 1zz tb today... thats about it, because its an auto..... what else can i do ti it?
#13 | |
![]() ![]() Drives: vitz rs Join Date: Apr 2011
Simply I reconnected stock denso ecu and I go. Very slow but I go. And I have all time to look and solve issue. Stock ecu is inside car so no prob to disconnect emanage harness and put toyota wiring. If I had standalone sure denso ecu rip home then if there's an electric problem engine does not start and car rip where it is.. mountains or seas. BUT.. emanage is headache cause billions of menu and parameters and not all is working.. idle adjustment not working properly or it is too difficult to me to understand.. it is japanese.. it is weird. If I decided to go standalone I buy apexi power fc. Yes it is japanese, all that's electical is japanese, but it has toggle to easily map onboard and costs 1000usd not aem standalone 2000usd. Why do Uu suggest aem? Is u official dealer? Do u provide all aftermarket support? Yes all of my temp e press gauges are aem working fine. Only egt probe lasted so short and I replaced with an other brand breaking after short and replaced with other brand 1 month ago. Then egt probe is short life. |
#14 |
![]() Drives: yaris, versa, geo, sprint Join Date: Mar 2015
well, megasquirt (last i checked) was mostly fuel injection and ignition timing. and maybe WBo2?
but the yaris has alot more its doing. not to mention the throttle by wire some cars have. its a PWM something signal that megasquirt is not able to work with. i cant speak for anything else, and my knowledge of MS is outdated. but the biggest problem will by the throttle body. throttle by wire is not something you want to mess with. not a lot is known on how they work/ how reliable they are with after market. |
#15 | |
![]() ![]() ![]() ![]() ![]() Drives: Toyota Yaris Sedan 09 STD Join Date: May 2009
#16 |
Drives: Toyota Vios NCP150R Join Date: Sep 2016
Hello Guys, i need help here for the Toyota vios / Yaris Sedan 2013 onward 1nz-fe NCP150R ECU Pinout Diagram.anyone know please email to Amin8391@hotmail.com. Thank you in advance.
#17 |
Nite Fury
Drives: Yaris Hatchback 1.5 S Join Date: Dec 2016
hi guys i own a standard yaris. if i get a retuning to the ECU..whta will the nearest top speed that could be added ? just curious..currently i can go 200kilometer per hour...
#18 |
Nite Fury
| Need Help with 2NZ ECU pinout | Aleil | DIY / Maintenance / Service | 3 | 12-28-2020 09:40 AM |
| I finally cracked the Odometer and SRS ECU code | CTScott | DIY / Maintenance / Service | 22 | 10-27-2016 01:50 AM |
| standalone and stock ecu | Radou | Performance Modifications | 0 | 06-16-2013 04:47 PM |
| Yaris ECU broken??!!!!!! | phb10186 | General Yaris / Vitz Discussion | 30 | 05-26-2010 09:56 AM |
| Tricking the ECU to Relearn AF map | gwasabi | Performance Modifications | 126 | 05-16-2009 06:15 PM |
