Coolant lines can be tapped from the heater core lines, and oil feed from under the intake manifold where the oil pressure sensor it. Just need a T fitting. Return for the oil will need to be tapped into the bottom of the block just above the oil pan.
#2 | |
![]() Drives: Toyota Echo Join Date: Feb 2014
I see alot of people tapping the block instead of using an oil pan, i guess due to oil loss? There is also a coolant feed halfway down the block on the exhaust side of the engine, has any one used this for a coolant feed before? |
| Zage turbo kit oil feed line fitting size?! | DKN-YARIS | Forced Induction Forum | 1 | 02-18-2014 12:18 AM |
| Need Feed Back | Asif | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 12-18-2012 06:07 AM |
| turbo feed lines | 1.5ty | Forced Induction Forum | 10 | 09-06-2010 11:41 PM |
| Afe intake feed back required. | 1NZYaris1 | Performance Modifications | 51 | 03-20-2009 08:25 PM |
