Coolant lines can be tapped from the heater core lines, and oil feed from under the intake manifold where the oil pressure sensor it. Just need a T fitting. Return for the oil will need to be tapped into the bottom of the block just above the oil pan.
| Zage turbo kit oil feed line fitting size?! | DKN-YARIS | Forced Induction Forum | 1 | 02-17-2014 11:18 PM |
| Need Feed Back | Asif | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 12-18-2012 05:07 AM |
| turbo feed lines | 1.5ty | Forced Induction Forum | 10 | 09-06-2010 10:41 PM |
| Afe intake feed back required. | 1NZYaris1 | Performance Modifications | 51 | 03-20-2009 07:25 PM |
