Old 02-22-2014, 09:40 PM   #9
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I've had my water temp probe in the drain spot on the back of the block for nearly 8 years. I used a ⅛ NPT fitting. You are correct, it was not the right one, but with thread sealant it went in far enough to not leak.
If you can't get the proper fitting, simply chase the fitting with a metric tap so it's not permanent like mine.
Zage turbo kit oil feed line fitting size?! DKN-YARIS Forced Induction Forum 1 02-17-2014 11:18 PM
Need Feed Back Asif Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 12-18-2012 05:07 AM
turbo feed lines 1.5ty Forced Induction Forum 10 09-06-2010 10:41 PM
Afe intake feed back required. 1NZYaris1 Performance Modifications 51 03-20-2009 07:25 PM
