Old 02-21-2014, 11:19 AM   #1
barryware
Thanks CT.. That is why I asked the question so I don't spend time chasing my tail.
I'll have to remove the CC module and check / clean all the connections and see if that makes a diff.
Something is loose / dirty.. Hitting bumps does make it drop out.
barryware is offline   Reply With Quote
Old 02-21-2014, 11:41 AM   #2
That's a tricky one. The Rostra has a crazy number of connections and of course you can't just wiggle wires while parked to troubleshoot it.
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 02:20 AM
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 09:42 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 01:59 PM
Replacement Map Light Switch? Meteorite_Marty Cosmetic Modifications (Exterior/Interior) 8 11-12-2013 11:18 PM
replacement fog light switch? yrsdrgn Cosmetic Modifications (Exterior/Interior) 4 07-17-2007 05:11 PM
