Old 11-07-2012, 11:01 PM   #1
Meteorite_Marty
Drives: 2008 5-door Yaris Hatchback
Replacement Map Light Switch?
Seems my switch is burned out on one of the map lights. It isn't the bulb. Swapped good switch to the "bad" side and it worked.
Now I have to replace the bad switch. The little white switch is marked "MS-010A" and is Japan Miyama Miniature Pushbutton Switch MS-010A.
http://www.federalcomponent.com/pdf/MS-010.pdf
Does anyone know where I can source one of these, or an equivilant? Is there a Toyota part number for it? I don't want to replace the whole map light housing when only the switch is bad.
Meteorite_Marty is offline   Reply With Quote
Bulb Replacement Guide (led Sizes) theFEVA Cosmetic Modifications (Exterior/Interior) 113 02-28-2017 12:02 PM
What are you doing right now? Bob_VT Off-topic / Other Cars / Everything else Discussions 26819 12-31-2010 10:48 AM
OEM fog light switch question kustom play Cosmetic Modifications (Exterior/Interior) 10 01-02-2009 06:33 PM
how to change the Map Light "Front Light" k3nn4 DIY / Maintenance / Service 0 11-02-2008 12:06 AM
MAP LIGHT drell42 Cosmetic Modifications (Exterior/Interior) 2 05-21-2007 07:30 PM
