#109 | |
http://www.yarisworld.com/forums/showthread.php?t=24860
#110 |
![]() Drives: Yaris Join Date: Sep 2012
Hi guys,
im new to the forum here.i am trying to install a yaris smart entry and remote start.i have a few wiring question such as follow : 1.Oil circuit detection 2.hand brake 3.cut oil and electric circuit off 4.door detection 5.windows regulating control for Yaris central locking wiring.what type of wiring is it?is it negative triggering or possitive triggering? btw my yaris 2010 5 door hatchback. i will really appreciate if someone can help me here. regards, Rhendy |
#111 |
by any chance..any1 can help me?
#112 |
I thought your post might have been spam with odd combination you were asking about, but since you sent me a PM with some specific questions, it seems like you are not a spammer.
In your PM you mentioned that you found all except these two: 1.Oil circuit detection 2.Cut oil and electric circuit off. For #1, the Yaris has an oil pressure switch that is located on the front of the block about 6 inches above the oil filter. It has a single yellow wire (since its case is grounded to the block). That yellow wire is only an input to the instrument cluster for the warning light. For #2, I am not sure what you are looking for. The only circuit associated with oil is that simple oil pressure switch.
#113 |
[IMG]
![]() [IMG] Uploaded with ImageShack.us[/IMG]thank you so much scott for replying.. i've attached the wiring diagram i received from the maker. the information i received for the"oil circuit detection"wiring has got to do with the fuel pump wiring.it is added as a security feature in anycase if somebody try to breakin in the car without authenticating the wirelesskey(force breakin).The engine wont start.it has something to do with shutting the car off. i think that in this case is not oil but fuel. |
#114 |
OK - That makes more sense for it to be the fuel cut-off. Sometimes the directions seriously lose something in translation.
In that case, you are interested in the violet wire on Pin 7 of the smaller ECM connector.
#115 |
the Y&W wire goes to Violet wire.
how about the Y&GN wire?where do i connect that wire? or do i connect both wires to violet? i read in your DIY Cruise control thread.A21 pin is located in the engine bay.is there any other location easier to access to fuel cut off? ![]() i am speculating based on your pictures.is that the correct violet wire? |
#116 |
I would need to see a better explanation of the module. In theory there should be two wires - in and out, so the device can interrupt the fuel pump feed.
#117 |
i manage to get the smart entry working well and fine with no problem.haha..
i take the fuel pump wiring from under the car seat. thanks scott for helping out. |
#118 | |
![]() Drives: Yaris TS 05 Join Date: Jun 2011
Maybe I have to tap de + with the Pin 9 and the - at the Pin 11? |
#119 | |
For the first gen, the red wire with the yellow strip in pin 9 is the high beam wire from the switch. That wire gets switched to ground when the high beams are flashed, so you would use pin 9 as your switched ground wire. You would want to use a relay that you switch the coil of with that wire, and then use the normally open relay contacts to trigger your garage door opener's switch.
#120 |
regarding to colors, I cannot rely
![]() lol ![]() Mines is a european base model so maybe for that the colors difference Ok I get it about the pin 9. So I tap here the - right? what about the + connection? Also the relay for what would serve? ![]() sorry for the question but I know almost nothing about this Last edited by fase4; 03-05-2013 at 08:58 PM. |
#121 |
yelcur
Drives: toyota yaris sedan Join Date: Dec 2013
please send full detail on toyota yaris sedan year 2008. .front totally damaged in accident .if someone selling parts let me know..! wiring system completely damaged.
#122 |
Drives: jdm wannabe yaris Join Date: Feb 2014
Hello everybody i missing a dimmer switch on my indonesian/thailand yaris 2012 5doors, i want to add tachometer on my yaris. Please help me :(
#123 |
The Asian market Yaris do not have the dimmer rheostat. You can either just use ignition switched power for the tachometer illumination wire of you can use the illumination wire on the radio.
#124 |
Problem, officer?
Drives: '06 Yaris 5DLB 1.5 Join Date: Oct 2010
My Thailand-spec Yaris uses electronic dimmer circuit built within the instrument cluster.
You have to toggle the trip button while having your lights on to access this function. |
#125 |
![]() Drives: Toyota Yaris 2007 Join Date: Jun 2014
Hi all. I'm planning to buy and mount a tachometer and water heat gauges on my Yaris 2007 Sedan. I've seen some loose wires and harnesses near the engin. These are unplugged . My yaris is number 2. It comes without RPM and Water heat Gauges. I bought it in Sultanate of Oman. My question is: does Yaris come with ready harnesses to plug and play my gauges? Otherwise, could you please show me how to mount them? What and where are the right wires located?
Thanks in advance Sent from my iPhone using Tapatalk |
#126 |
Drives: 06 hatch Join Date: Oct 2014
hey man i was wondering if you could tell me how to go about installing footwell led lights to be activated with a switch prefferably in the center console by the e-brake. i know you have to bypass the firewall somehow for power, but i have no idea how/where to do so. help would be greatly appreciated.
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 04:45 PM |
| 2012 Yaris at SEMA | Jason@SportsCar | Third Gen Yaris General Discussion | 5 | 09-23-2013 04:55 AM |
| New Yaris race car | Jason@SportsCar | Tracking, Racing, Auto-X Forum | 83 | 11-01-2012 03:32 PM |
