Old 03-04-2014, 05:54 AM   #1
Klink10
Klink10's Avatar
Hey Tooter.....Let me get the funds transfered over to checking and I'll get one to you ASAP. One more question....you had mentioned that one hose had to be lengthened to fit on the tooter. Can you point out which one in one of the pics showing the tooter installed? Got to figure out a clean way to do that. Thanks
Edit: Also are you using Loctite on those studs and without me having to look, what is the torque setting and tightening sequence?
Old 03-04-2014, 11:12 AM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
There's no rush, Klink. I'll likely be doing more small production runs if needed.
Sure. I'll post some close up pics when I get some time off work. From running the aluminum tooter intake manifolds, my hoses were all switched around so what you'll see will have no relation to the stock setup!
I've never torqued the intake bolts and didn't use any locktite on the longer spacer studs. I just go by feel and snug everything down evenly with a few sequential passes. With all of my intake experiments I've likely taken more manifolds off and on than anyone else here and have never had any issues.
Greg
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
stock scion xa exhaust and intake manifold and others taman86 Items for Sale by private party 0 09-27-2012 02:39 PM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 08:03 PM
