![]() Drives: Toyota Vitz 2010 Join Date: May 2013
Hi, if i have thermostat stuck closed. Would that affect the fan?
Thank you |
#2 | |
The thermostat being stuck closed would prevent the coolant from getting to the temperature sensor, which is mounted to the radiator. Also, that sensor being bad could prevent the fan from running.
| Another case of Overheating Problem | Slacky | DIY / Maintenance / Service | 5 | 01-24-2014 02:22 PM |
| Toyota C160 Reverse Gear Problem | Parmas | DIY / Maintenance / Service | 2 | 12-01-2010 01:30 AM |
| Problem Starting Car | drunkwithwords | General Yaris / Vitz Discussion | 3 | 07-21-2010 04:01 PM |
| Launching @ 4Krpm problem .... need tips | Parmas | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 12-30-2009 08:11 PM |
| How can I get in touch with Toyota Regional Offices in Houston? | woof | DIY / Maintenance / Service | 11 | 11-28-2009 09:29 PM |
