Old 01-21-2014, 07:55 PM   #1
Slacky
Slacky's Avatar
Drives: 2007 Yaris Sedan
Another case of Overheating Problem
Hi All:
Yesterday it started with the temperature icon blinking red on the dashboard and went away. Today I checked and found pink fluid around the pulleys, belt and in the hood. Tried to recreate the issue and found some small coolant leaks. I noticed that if I turn on the AC I will speed up the issue.
Details:
- Fan runs normally.
- Refilled the radiator with green coolant without flushing to trace the
circulation. Leakage continue to be pink from parts attached and found
another small leakage in tube that goes from the radiator to the
thermostat.
Should I replace the thermostat and all the tubes and pipes that are leaking????
Slacky is offline   Reply With Quote
Old 01-21-2014, 08:17 PM   #2
Your waterpump is bad, hence the coolant on the inside of the waterpump pulley. The hoses with the pink on them are A/C refrigerant hoses.
Old 01-21-2014, 09:15 PM   #3
alanwagen
water pump
I agree, it is the waterpump. Replace ASAP.
Old 01-22-2014, 03:39 PM   #4
esse10
Drives: 2009 yaris 2 door
x3
x3 seems like your water pump has KAPUUT. I would replace asap and don't mix green coolant in your system or it'll contaminate the long life pink coolant from Toyota and cause more problems in the near future.
Old 01-22-2014, 04:22 PM   #5
Slacky
Slacky's Avatar
I just received the water pump (Aisin), thermostat (Original) and new 50/50 coolant.
Old 01-24-2014, 02:22 PM   #6
Slacky
Slacky's Avatar
Problem Solved! Was the water pump.
Thanks for the help.
Toyota C160 Reverse Gear Problem Parmas DIY / Maintenance / Service 2 12-01-2010 01:30 AM
'54 T2 Yaris 1.0 VVTi automatic clutch / gearbox / starting problem Lettuce UK 0 09-30-2010 06:21 AM
Problem Starting Car drunkwithwords General Yaris / Vitz Discussion 3 07-21-2010 04:01 PM
Yaris Central Locking Problem pbasuita UK 0 07-10-2010 03:46 AM
electrical problem with car need help badly!! Adriaan DIY / Maintenance / Service 20 05-07-2010 12:40 AM
