![]() Drives: Toyota Vitz 2010 Join Date: May 2013
Fan was running normal, before repair the radiator, so i assume its ok after reassemble. I also placed an obd connector and checked the coolant temperature. Reads up to 90 in normal circulation, but when i run up an inclined road, the temperature increases near to 100 where i stop to prevent damage.
#2 | |
As suggestion from a friend, I found today a used radiator from a previous model (99) things are pretty similar. Tomorrow Im replacing the radiator and keep testing.
Thank you all for the input, I will double check this time that fan is correctly plugged |
| Another case of Overheating Problem | Slacky | DIY / Maintenance / Service | 5 | 01-24-2014 02:22 PM |
| Toyota C160 Reverse Gear Problem | Parmas | DIY / Maintenance / Service | 2 | 12-01-2010 01:30 AM |
| Problem Starting Car | drunkwithwords | General Yaris / Vitz Discussion | 3 | 07-21-2010 04:01 PM |
| Launching @ 4Krpm problem .... need tips | Parmas | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 12-30-2009 08:11 PM |
| How can I get in touch with Toyota Regional Offices in Houston? | woof | DIY / Maintenance / Service | 11 | 11-28-2009 09:29 PM |
