Old 03-21-2014, 08:55 PM   #12
dragoonmc
Drives: 07 hatchback
Hey got mine installed last night. With the stock air box this is kind of hard actually.
Things that are probably worth Mentioning are that the vacuum lines need extended, the sensor just off the throttle body cannot be mounted back into the boot due to the length of the wires. The coolant hose that comes up and over the manifold is actually long enough on its own, though the lower one does need extended or replaced if you can get it the other end off.
Without anything mounting the wiring harness that runs across the engine this might eventually lead to fatigued and broken wires, I will figure out something to attach that to and hopefully re attach the decorative cover
dragoonmc is offline   Reply With Quote
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
stock scion xa exhaust and intake manifold and others taman86 Items for Sale by private party 0 09-27-2012 02:39 PM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 08:03 PM
