#1 | |
Drives: Yaris Sedan Join Date: Aug 2014
How long did it take to get these lugn
ut online it is showing me they will not ship until 9-6-14 |
![]() ![]() Drives: 08 hatchback Join Date: Jun 2011
The picture that I posted is with stock lug nuts but I ride after market acorn style lugs I got from ebay, I don't know if the ones I posted are the right size but it's that style . And some recent pics with the new wing.
http://www.ebay.com/itm/LUG-NUTS-BUL...item3cbf8f4802 |
#4 | |
that looks really nice
![]() ![]() ![]() Drives: 09 Yaris 3dr HB, BRZ Join Date: Mar 2011
Big fan of the mini wheels myself.. but one question how heavy are they? Had a set lined up but he wanted too much for em, set of 4 with only 3 decent tires for $400. Didn't realize there was more to the fitment than just hub centrics though..
It varies by rim type, but the 15" 5 spoke mini wheels that I ran for a while were about 4lbs lighter per wheel than steelies.
Your car is looking good. Those bulge-type lugnuts should be OK. At least the larger conical section makes full contact with the taper of the rim hole, whereas with the stock ones there is very little contact area.
![]() Drives: Black 2012 SE manual Join Date: Feb 2013
quote> those bulge-type lugnuts should be OK. At least the larger conical
section makes full contact with the taper of the rim hole, whereas with the stock ones there is very little contact area <quote Thanks for the advice CT.. I couldn't locate any extended tip nuts which would fit my wheels. The 0.625" extended tip diameter would not clear my 0.595" rim thru-hole. So I similarly purchased bulge-type nuts which do cover the 0.800" outer conical area. |
MINI wheels look great on our cars!
OK. So, you have a set that used 12mm lug bolts. Some of the mini rims use 12mm and others 14mm. The ones that I had were from a mini with 14mm lug bolts.
Bronze on blue looks good so will white tire size good for saving gas :)
Sent from my XT1032 |
GRO H2O
Drives: Yaris Join Date: Apr 2011
Look like I'm gonna have to order lug nuts online as no local tire/wheel shops carries anything lug nut wise. Will be $78 CDN after shipping/border extortion fees for 20 (only packs of 5) of these http://www.jegs.com/i/Detroit+Wheels...395-5/10002/-1
Will post back with photos. |
![]() ![]() Drives: '08 SEDAN 5 SPD. Join Date: Aug 2009
#15 | |
GRO H2O
Looking at Canadain online parts market looks like there's a void to be filled as there's not much in Canada for online car part retailers. WIsh I had a mil or two to start one. |
GRO H2O
LOl I stand corrected, they arrived yesterday. I broke my torque wrench so can't put them on today and will have to take them to a shop tomorrow morning.
GRO H2O
Finally got around to it. En not sure if I like them on a stock height car :P would have been much nicer the they came in 16".
The rear to tuck in quite a bit so maybe a spacer will be needed to make it more flush. yaris_r81_01.jpg yaris_r81_02.jpg yaris_r81_03.jpg |
I love the phone dials on a Mini, but you're right - They do look a little small on a Yaris. Maybe if they were white, it would give the illusion of them being larger?
| Question about these rims. | Bar_Red_Yaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 06-09-2011 08:54 PM |
| My 17" alloy rims and Kumho tires... will swap for your original wheels! | AutoWashCars | NY / NJ/ CT / PA | 5 | 02-08-2011 07:38 PM |
| RIMS a Noob-toob question =] | donchae | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 45 | 10-17-2010 06:11 PM |
| Question about Rims | MrJester | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 03-06-2007 10:16 PM |
| hufeisen rims | JustYYaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 01-17-2007 03:16 PM |
