Old 03-27-2014, 06:41 PM   #1
Originally Posted by Black_griffin6 View Post
Worst case scenario, would I be able to drive it if I bypass the AEM and drive it gently on the 1zz injectors? And stock ECM?
Do you have a fixed or clutched pulley? If you are fixed, I would not risk it. You could get a shorter belt and bypass the S/C for now.
Old 03-27-2014, 06:43 PM   #2
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
Yeah, I do have a shorter belt, I'm not sure what size I need though.
Black_griffin6 is offline   Reply With Quote
Old 03-28-2014, 06:54 AM   #3
The easiest thing is to pull of the existing belt and measure the size required. You can lay a piece of non-stretching rope over the path of the belt and then measure it. Make sure you go over the S/C tensioner pulley, as the alternator is now fixed.
Old 03-28-2014, 11:18 AM   #4
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I second this idea. I ran lean at WOT even with the blitz controller on the factory injectors. I'd be afraid to run it on those without the blitz controller in place.
For the belt, I'd just go to a parts store and buy a few different belts somewhere 50 and 60 length. Try a few out until you find one that fits right and return the others.
List of Boosted Yarisworld Members whooppee777 Forced Induction Forum 262 11-23-2022 05:49 AM
Car wash causing electronic problems? lamadoo DIY / Maintenance / Service 3 12-24-2013 10:47 AM
follow up on 2010 yaris problems + more problems heavenswaitin DIY / Maintenance / Service 18 09-03-2013 03:47 PM
Blitz Supercharger and AEM Water Methanol Kit Morgan Items for Sale by private party 18 01-25-2010 10:54 PM
Pre-Hack Repost: DIY Eaton Supercharger, Why Not? Nexus1155 Forced Induction Forum 67 01-10-2009 01:23 PM
