Old 03-28-2014, 11:56 AM   #1
Originally Posted by scumfromohio View Post
Didn't seem to fix what I can add is, it seems my reserve stays full but the engine coolant neck loses what I put in it and gets no more. Like this morning it was empty but reserve was full and it was still overheating. So I waited for it to cool down and poured it straight in the radiator cap and it's fine.
Sent from my SCH-I545 using Tapatalk
So, you either still have air in the system or you have a leak. I find that to get all of the air out you have to leave it running for a crazy long time (like 30+ minutes in cold weather)
Old 03-28-2014, 12:26 PM   #2
scumfromohio
Drives: 08 White Yaris
Yeah I left it running for at least 45 minutes, I'm thinking there's gotta be a leak somewhere cause of how fast it's losing coolant. I work maybe 50 minutes away and the coolant was out of the engine filler neck twice. So it was completely empty 2 times and I poured it in there 2 times. But idk at this point
scumfromohio is offline   Reply With Quote
Old 03-28-2014, 12:44 PM   #3
Is there significant white smoke out of the exhaust?
Old 03-28-2014, 12:45 PM   #4
scumfromohio
None what so ever, but I pull over as soon as the overheat light blinks.
Old 03-28-2014, 12:55 PM   #5
Hmmm. And, no sign of wetness under the hood? Any sign of moisture or smell of coolant from the A/C vents?
Also, remove the oil filler cap and see if there is any foaminess on the bottom of it.
Old 03-28-2014, 01:03 PM   #6
scumfromohio
There's no smell of coolant inside the car or from the vents. It's hard to say about wetness under the hood cause I'm not the most accurate coolant pourer. Haha so I've spilled a bit. I'll check for foaminess tonight. I was thinking about renting a pressure tester tomorrow and giving that a shot what do you think? Thanks for all your help man.
Old 03-28-2014, 01:18 PM   #7
Pressure tester might not be a bad idea. Also, I have noticed that if you disconnect the radiator with hoses that are a few years old and reuse the hoses, that they often don't reseal well unless you replace the stock hose clamps and tighten the heck out of them.
Car wash causing electronic problems? lamadoo DIY / Maintenance / Service 3 12-24-2013 10:47 AM
follow up on 2010 yaris problems + more problems heavenswaitin DIY / Maintenance / Service 18 09-03-2013 03:47 PM
Yaris problems and solution ubospawis Middle East 26 01-12-2011 03:41 AM
A few problems drunkwithwords General Yaris / Vitz Discussion 1 04-01-2010 11:13 AM
Problems? Twistoffate0817 General Yaris / Vitz Discussion 35 12-24-2008 11:53 AM
