Old 03-28-2014, 12:44 PM   #1
Originally Posted by scumfromohio View Post
Yeah I left it running for at least 45 minutes, I'm thinking there's gotta be a leak somewhere cause of how fast it's losing coolant. I work maybe 50 minutes away and the coolant was out of the engine filler neck twice. So it was completely empty 2 times and I poured it in there 2 times. But idk at this point
Sent from my SCH-I545 using Tapatalk
Is there significant white smoke out of the exhaust?
Old 03-28-2014, 12:45 PM   #2
scumfromohio
Drives: 08 White Yaris
None what so ever, but I pull over as soon as the overheat light blinks.
scumfromohio is offline   Reply With Quote
Old 03-28-2014, 12:55 PM   #3
Hmmm. And, no sign of wetness under the hood? Any sign of moisture or smell of coolant from the A/C vents?
Also, remove the oil filler cap and see if there is any foaminess on the bottom of it.
Old 03-28-2014, 01:03 PM   #4
scumfromohio
There's no smell of coolant inside the car or from the vents. It's hard to say about wetness under the hood cause I'm not the most accurate coolant pourer. Haha so I've spilled a bit. I'll check for foaminess tonight. I was thinking about renting a pressure tester tomorrow and giving that a shot what do you think? Thanks for all your help man.
Old 03-28-2014, 01:18 PM   #5
Pressure tester might not be a bad idea. Also, I have noticed that if you disconnect the radiator with hoses that are a few years old and reuse the hoses, that they often don't reseal well unless you replace the stock hose clamps and tighten the heck out of them.
Old 04-01-2014, 07:27 PM   #6
scumfromohio
OK so pressure test was fine it stayed the same pressure for 10 minutes. We ran it for a good while and after an hour or so coolant started coming out the reserve again, but the filler neck and radiator cap are both brand new.
Old 04-01-2014, 08:48 PM   #7
Coolant will go into the reserve tank as it gets hot and expands. Is it overflowing the reserve tank?
Car wash causing electronic problems? lamadoo DIY / Maintenance / Service 3 12-24-2013 10:47 AM
follow up on 2010 yaris problems + more problems heavenswaitin DIY / Maintenance / Service 18 09-03-2013 03:47 PM
Yaris problems and solution ubospawis Middle East 26 01-12-2011 03:41 AM
A few problems drunkwithwords General Yaris / Vitz Discussion 1 04-01-2010 11:13 AM
Problems? Twistoffate0817 General Yaris / Vitz Discussion 35 12-24-2008 11:53 AM
